Get 500 EcoCredits, Worth $5
Join Now
Existing user? Log in
Existing user?
Join Now
#powerdifferent
#PowerDifferent. Forgot to add the tag. Check out my new 4kw array that I just added to my garage. It allows me to remove the 4kw on the ground off. I Still have 1600 watts on the ground for the LV input of the DPU .
Allows me to not worry
Adding more solar never hurts.
The racks on the 200W are ones I just purchased to test out. I recommend them. They work from 100 watt to 500 watt. The larger panels will only be able to lift 34 degrees. If you want racks for your RV, Shed and ground array hit me up and I share the info.
Log in
0 / 1000
Send
All Comments1
