Get 500 EcoCredits, Worth $5
Join Now
Existing user? Log in
Existing user?
Join Now
Smart Generator Dual Fuel – Gasoline or LPG ⛽⚡
Today I’m going to share a few more technical details with you—this time about the EcoFlow Smart Generator Dual Fuel.
The generator can run on either gasoline or propane.
Performance specifications according to EcoFlow:
• 1,800 watts rated power with gasoline
• 1,600 watts rated power with LPG
• 4-liter gasoline tank
• Approximately 5.4 kWh of energy generated per tank under test conditions
• App control via Wi-Fi and Bluetooth
• Automatic start and stop function with compatible EcoFlow systems
• Built-in alerts for carbon monoxide, oil level, temperature, and overload
The automatic function can start the generator when the battery is low and shut it off again after charging. Very important: A combustion generator must be used exclusively outdoors and at a sufficient distance from doors, windows, and ventilation openings. The built-in CO sensor is no substitute for safe placement.
#EcoFlow #SmartGenerator #DualFuel #EmergencyPower #Camping
This content was automatically translated.
Log in
0 / 1000
Send
All Comments4
