EcoFlow STREAM in a Rental Apartment—My Thoughts After the First Few Months
Greetings from the North! 👋
I rent an apartment in a multi-family building in a major city and use an EcoFlow STREAM system with STREAM Pro and STREAM AC on two phases. Together, they provide 3.84 kWh of storage. I find the multi-phase feed-in very practical when dealing with higher loads.
My balcony PV system is rather small and, due to the landlord’s restrictions and its orientation, isn’t ideal. Nevertheless, during the sunny months, I achieve nearly 100% self-sufficiency—though that was never my actual goal.
My main goals are to reduce electricity costs, better understand my consumption, supply the base load with solar power even when I’m away, and have some backup power security.
The refrigerator, router, smart home devices, and my small server can all continue to run via the AC outlets. Of course, the capacity isn’t enough to cover a seven-day power outage without sunlight, but for shorter outages, this is a real benefit for me.
I use the EcoFlow Smart Meter to track my energy usage. Setup was straightforward, and the system has been running very reliably so far. A nice bonus is its integration with Home Assistant.
Since I have limited space, I also like that the storage units can be integrated discreetly.
I don’t have any data for the winter yet. Due to panel output and orientation, self-sufficiency will certainly drop significantly. If I can cover a large portion of the base load during the day, I’ll be satisfied.
My tip: Don’t just buy the largest storage units you can—instead, tailor them to your PV output, orientation, and consumption. Six storage units are of little use if the PV system can barely charge them. That’s why I like the modular design: start small and expand later.
Looking back, if I were planning from scratch, I probably would have gone straight for the STREAM Ultra X because of its higher capacity in a single unit. For me, though, it was also a matter of space at the time.
All in all, I’m very satisfied: straightforward, flexible, reliable—and it’s just fun. ☀️
