Small Power Station. Big Possibilities. 🔋💪🏾
Listen—you don’t need a big budget or a big power station to get started. You need a setup that works for YOU. 🔋
Can’t afford a DELTA Ultra or Ultra Plus? Start smaller. Figure out what you want to run and how you’ll recharge—solar, a generator, or both. Then buy what fits your needs AND your pockets.
I started with a DELTA 2 Max and a RIVER 2 Pro, and they worked for me! I have a DELTA Pro 3 now, but I built up slowly. My pockets aren’t that deep!
I found used and new solar panels on Facebook Marketplace, used for no more than 50 cents per watt. Found some deals on Amazon, too. Little by little, I built my setup—and those smaller units are STILL putting in work.
So get that DELTA 3 Max Plus, that DELTA 2 Max, or whatever fits your budget. Don’t let somebody else’s big setup intimidate you.
Start small. Build smart. Make what you can afford work for YOU. 💪🏾
