Power Electronics: The quantum-level "Self-Healing" inside high-power inverter capacitors
Inside high-power conversion hardware like the DELTA Pro Ultra and PowerOcean inverters, the DC-bus link must smooth out massive voltage ripple from incoming solar and battery lines. Traditionally, high-capacitance needs were met using electrolytic capacitors. However, electrolytic capacitors fail catastrophically under high ripple currents due to electrolyte drying and internal short circuits.
To ensure long-term reliability, EcoFlow high-power architectures utilize Metallized Polypropylene Film Capacitors. Beyond their ultra-low Equivalent Series Resistance (ESR), these capacitors possess a physics property known as Dielectric Self-Healing. The capacitor's electrodes consist of an ultra-thin metal layer (aluminum or zinc) evaporated onto a polymer dielectric film at a thickness of only 20 to 50 nanometers. If a localized high-voltage transient causes a microscopic dielectric breakdown, an electric arc begins to form at the weak spot.
However, because the electrode metallization is nanometer-thin, the high fault current density instantly creates a microscopic thermal plasma. In less than a microsecond, this localized heat completely vaporizes the thin metallic coating immediately surrounding the fault site. The metal vapor expands outward, leaving a clean, non-conductive boundary around the defect. The short circuit is cleared automatically without any drop in system capacitance or interruption to the inverter.
