Get 500 EcoCredits, Worth $5
Join Now
Existing user? Log in
Existing user?
Join Now
Delta 3800 Gen4 Useable Capacity and Round Trip Efficiency
Everyone can lookup the specs of the new Delta Gen4... here are some figures you might want to know from my testing. Two tests one at common .2C Rate, and then I cranked it up to a more aggresive ≈ .45C rate.
Delta 3800 Gen4 Useable Capacity Test
100 % to 0% full discharge @ ≈ .2C rate (752W)
3340Wh useable capacity of 3763Wh specification
= 89% Useable Capacity
This is consistant with what i've seen some others achieve.
Delta 3800 Gen4 input Charging Test
0% to 100% full charge @ ≈ .2C rate (752W)
4360Wh input
Round Trip Efficiency (3340 / 4360) = 77%
Round trip efficiency might be important to know for those people using TOU (Time of Use) or Peak/Rate shaving. When calculating your savings some don't consider the energy conversion and efficiency. For Example if your peak rate is 50 cents and your low rate is 5 cents - you have a spread of 45 cents. However you must factor the RTE for a more accurate REAL savings (plus cost of equipment but that's another story)
_____
Here are the figures from more aggressive ≈ .45C rate - higher load discharging, and faster re-charging. Higher rates, more heat, generally slightly worse for battery health.
100 % to 0% full discharge @ ≈ .46C rate (1735W)
3400Wh useable capacity of 3763Wh specification
= 90.4% Useable Capacity
0% to 100% full charge @ ≈ .44C rate (1635W)
4200Wh input
Round Trip Efficiency (3400 / 4200) = 81%
Log in
0 / 1000
Send
All Comments18
