☀️ Surplus electricity turns into hot water — try my-PV with EcoFlow
Hello friends at EcoFlow!👋
Any leftover photovoltaic power during the day can be used to boil water.🚿☀️
After connecting my-PV to the EcoFlow home energy system, you can manage compatible heating rods within the EcoFlow App, making the solar energy at home more useful.
Currently, it only supports OCEAN 2 and OCEAN 2 Single-Phase along with AC ELWA 2.
💡 What can I do after binding my-PV?
☀️ Use the remaining electricity to boil water
In solar mode, the heating rod uses residual photovoltaic electricity to heat water to the preset solar target temperature.
🌡️ Manage heating as needed
It supports two modes: manual mode and solar mode. Manual mode supports boost heating, and turning on the heating switch quickly heats the water to the preset water temperature.
⏰ Automate tasks
There are two types of automated tasks: timed heating to the minimum temperature and timed sterilization.
📊 See clearly where the electricity comes from
Open the data dashboard to check heating rod electricity usage by daily, weekly, monthly, and yearly views.
📲 Ready to give it a try?
Bind AC ELWA 2 in accordance with the guidelines, set the temperature, and add it to redundant PV priority. Once added, the device will switch from manual mode to solar mode.
📸 It's all set up. Let's take a look!
Post a screenshot of the bound device in the comments and tell us:
Is it just set up, or has residual electricity been used for heating?
If you're already using it, you can also post a screenshot of the data dashboard and write about something you've noticed so far.
Still in the setup? Tell us where you're stuck and what you see in the app, and the community can discuss it together.
Before sending screenshots, please conceal your personal information or device SN.
Come and show off your photovoltaically heated water! ☀️👇
