Get 500 EcoCredits, Worth $25
Join Now
Existing user? Log in
Existing User?
Join Now
Making accidental shutdowns less likely.
I’m wanting to use an Ecoflow Delta 3 as a UPS, but any touch of the AC port buttons could shut everything down in the worst possible way.
Do you know of any way to make this less likely to happen?
UPSs usually require you to hold the button down for a few seconds before switching it off/on.
The only way I’ve found so far is a physical lock on the button; I’m planning a 3D print for this, but I didn’t want to have to go that route.
Should be good to heve to enable/disable an option in the app where the buttons should be pressed for a few seconds before executing the action.
Log in
0 / 1000
Send
All Comments4
