Existing User?
Join Now
Home/Ask Me Anything/Accessories/Charging Stations with Overperforming Solar is Great to See
Hot
Once the sun angle in the frozen north makes it viable to recharge my stations with solar panels on a regular basis, I use my stations a lot for running household items. Last week I was recharging a Delta 3 Plus and Delta 3 Max Plus on a partly sunny day. Because of the conditions, I was unsure if they would get charged all the way.
The rigid panels I have on my shed are 320w each. Each panel is run with its own wiring to its own connectors. That means I can I can use the panels however I like, depending on what station(s) I am charging; run individually, some in series or some in parallel. In this case, each of the stations had 1 panel hooked into each of the PV inputs (both stations have 2 inputs). So, each station had the possibility of getting 640w input in perfect weather conditions. However, with the cloudiness, much of the time they were only getting 130w-200w total.
Shortly before 3 pm, I looked on my app and some some outstanding numbers. Over 700w were going into both stations!!! Now, this was a short term effect, when the sun had broken thru the clouds, but it was awesome to catch. The overproduction of the panels was caused by several factors; colder air temperature at 40*F, there was a fresh snow fall to create some reflection, and the "edge effect" from the sun interacting with the clouds (this was probably the biggest factor).
Can't complain with an 18% overage of production from the panels, and it certainly helped get the stations fully charged that day.
+2
319
34
102
Join the conversation!
Please keep discussions civil and respectful, and follow our community guidelines
0 / 1000
Send
All Comments34
Latest
There are currently no comments to display
